disable web http
disable web http
Description
Disables the hypertext transfer protocol (HTTP) access to the switch on the default port (80).
Syntax Description
Default
Disabled.
Usage Guidelines
Use this command to disallow users from connecting with HTTP. Disabling HTTP access forces a user to use a secured HTTPS connection if web HTTPS is enabled.
Use the following command to enable web HTTPS:
enable web https
The following command disables HTTP on the default port:
disable web http
This command was first available in the ExtremeXOS 11.6.
Platform Availability
